substatica
New Member
- Toronto
This is my second weld with a Lincoln Weld Pak 100 with gas. Seemed to be spattering a lot, I had the power at D (the highest) and wire speed at 5 of a possible 10, any advice? Cheers
For first welds, or second as the case may be, they are pretty damn good.
I can see you have cleaned the steel prior to welding though hard to tell if it could have done with a bit more of a clean up.
If your machine is 100amps max then that steel (is it 3mm) may be just a bit above it's limit, the weld looks a bit cold.
The dirty sooty deposit could be from the steel, could also be a shortage of gas, simply not enough pressure or the angle of the torch.
Wire speed may also be having an effect, did it sounds nice or was it spluttering a lot.
Get some very clean steel a little less thickness but not too thin, should think 2mm would be ok for that machines top power and have another go, do a few runs with different wire speeds and you should find one that has a nice even sound, wire feed on some machines can be very very touchy and even the smallest of turns can make a significant difference.
1 cu.ft. = 28.3 litres, 15 cu.ft = 424.5 litres
10 lpm is about the norm that most people use, up to 15 lpm if there is a risk of any minor draughts affecting the gas, major draughts make a bigger difference but you would then tend to see other effects that your welds are not showing.
Laying beads wont be a problem on that thickness i believe. But try joining two pieces together (later on) and youll find the penetration wont b e very good at all. minse a 135 amp and that wouldnt touch 6mm steel.
but they look good.
if im right in saying (as im newby too) they look a bit ''cold'' looking at the toe lins. is this a correct statement?
To be fair your correct about the join wont ever be good enough but also that feeds back to the plant not having the power to melt a proper pool and yes it will effect the weld process even in practice as you will be pushing wire into a rapidly cooling pool, it will feel like the feed is too fast. Thicker metal soaks up more heat its that simple
I was beginning to see the pool, from all I've read I was expecting the pool to be glowing orange when I observed the wire feeding into a pool during this weld the pool was not orange but just looked like liquid metal that the wire was pushing into -- does that mean it's too cold, or is that the pool everyone talks about?
its too light a shade for you most likely, we all have slightly different rates of dilation I think
