mark williams
- Wrexham
What do you guys use for degreaseing ?
I prefer carb cleaner over brake cleaner. I found it more effective. Probably not good for yer 'elf though...
Its the same stuff according to my supplier who sells me a gallon labeled brake, clutch and carb cleaner!!!
It may turn into phosgene (although I can't find any chemical relationship as to why and would love a link that explains it) however once evaporated and wiped away there is nothing left. I am still here and of course you use fume extraction don't you?
What about cellulose thinners to get the oils and grease off metal before welding, is that OK or safe?
I generally soak a rag in the stuff then wipe down the tube, then let it evaporate, open door type thing and the rag and can well away from the welding area before I start.
Adrian
isopropyl alcohol or white spirit whichever comes to hand.
