mart
- South Yorks
I bought a couple of these outdoor spot lamps from Amazon (The make is ELRO. Type BYRON PL01).They seem to be a nice compact weather proof lamp, and are IP44 rated.
I’ve had a look inside the swivel base where the standard block connecter is, but there is no “proper” access point for the incoming electric cable. When I say “proper” I mean there are no recesses or cut-outs anywhere. I could always drill a hole or cut a bit of the plastic away on the side, but is this normal for things like this? There is no purpose made “week point” to knock through, like there is with socket back boxes etc. Even doing this, I think I would struggle to put armour cable to it (if it is mounted away from the house) , as the depth of the base is only 14mm. At least with flat TW&E I would be able to get some of the outer sheaf inside the base Any thoughts on the access issue on these lamps?
http://www.amazon.co.uk/gp/product/B002LSHNB8?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
