Guy Burnett
New Member
- London
Hello,
I have recently bought a Clarke 135TE with the intention of welding together some mild steel structures. I have carried out a number of tests on 1.5mm thick mild steel tubing and have managed to weld pieces together. However the welds are very weak, with a bit of force I am able to pull them apart.
I am using the CO2 gas that came with the welder and 0.6mm wire. To start with I used the control settings that the manual suggests (Welding Position - 1 & Max, Wire Speed 6 and gas flow on 4) however I have also carried out tests with other settings.
My work surface is a large 3mm mild steel sheet. I am working in a large garage with the door but there is no draft.
I have watched tutorials and used the manual throughout but obviously I am doing something wrong. Any help you can give me would be hugely appreciated! I have attached some photos of the steel after I have pulled the welds apart.
Also, if you may know someone in London, UK, who might be able to help me that would be great!
Many thanks,
Guy
Many thanks,
Guy
