- Birmingham
Mind you, I hate SWA with a passion, so try and avoid it wherever possible!
I don't mind working with it up to 25mm², over that it puts up a fight when dressing it in.
I'd rather work with 95mm 4 core SWA than 2.5 flat twin any day!Yep, I'd agree, urgency and convienence are usually a factor, and most isn't urgent and I'm a bit lazy, so I spec 3-coreMind you, I hate SWA with a passion, so try and avoid it wherever possible!
It is actually illegal to do anything, with the DNO cut out.well I know it's illegal to downgrade a fuse, will check the legalities of putting a bigger one in
who gives a tossUnless you're qualified and authorised?
does the sheath always give a suitable earth path? (assuming terminated correctly)
I won't mention EAWR then!who gives a tosshalf the time i do new fuseboxes and the tails are big enough i just do em live so they cant say anything
Try getting qualified & authorised unless you are a DNO employee, from a metering company or say for example a local authority street lighting employee.
Or, you are an authorised contractor to the DNO.
I've tried as I do work for the local health board that requires total disconnections of supply @ patients homes, no chance, no matter what.
hmm its a bummer when u have to blow your own trumpetLooks like I'm good then![]()
hmm its a bummer when u have to blow your own trumpet![]()
