if there surface mounted u need the base plate mounting for them as on there own there only suitable for suspended ceilingsAs I don't have any lights to start with I am looking at LED as an option to tubes, there are quite a lot of options for 600x600 flat panels like these http://www.ledhut.co.uk/commercial-led-lighting/40-watt-high-output-595-x-595-led-panel.html
All seem to be aroubnd £70-£80 for a 40W fitment with about 2000-3000 lumens. Thinking 4 of these in a 5m x 3m room instead of tubes.
They can be surface mounted and have a very low profile which appeals as I want to sling some moveable gantry to help move stuff about.
Cheers,
MM
Thats what my mate did I am sure he put 240v direct to the tube ends and on 8ft he used 2x 4fts with extra lamp holders in middle.Andy from what I have read,you wire them directly to 240v, bypassing the choke,ballast etc
look at post 25For 600x600's you can get a direct fit replacement unit that's LED, rather than tubes. Has a 100% FYA on it as well (so you can write it off against tax 100% in it's first year) and they use about half the power of normal units. Worked out a trade counter of ours would save £15 a month by swapping them.
Ack, my bad. I've been moving the girlfriend's house into my man cave today, in advance of the new house at the end of next month! Bloody knackered...look at post 25![]()
i need talk some of the ****** ive been dropping latelyAck, my bad. I've been moving the girlfriend's house into my man cave today, in advance of the new house at the end of next month! Bloody knackered...
ive stood in the corner and had a word with myself
ive stood in the corner and had a word with myself![]()
Most constructive argument you'll have. And you won't hold yourself to a decision in the heat of the moment either...Just as long as you don't start an argument with yourself, you'll be fine![]()
Why are you replacing them is there is none?We're slowly replacing all our tubes with LED's and as there are literally 000's across the site, the energy savings are considerable.
