burrows1980
- Buckley, North Wales
Hi,
In my last garage I did a similar setup after following the guide on here, today Ive installed one in my new garage ready for spraying my car. Heres some pics:
Ive got two Norgren filter/Regulators, one on each side of the garage, handy saves have a hose trailing everywhere, I aquired two a few years back so might as well use them..
Im not going to use the flexi pipe, using that from the compressor to the start of the pipework..
A gauge to show pressure in pipework, meant to put one in on the other side, probably a slight drop in pressure this side due to the extra pipe run..
Pipe work goes out into outhouse where the compressors going to be stored, epoxy'd the floor on Friday and second coat yesterday so cant go in there for a week now!
I kinda wish when I built it beginning of this year, I'd made it bigger but only compressor, lathe, lawn mower, bikes ......... going in there
Got plenty of drops in the setup, 9 in all:
Bonnets in the way, but you get the idea.
Its sloped from one side of the garage to the other, to aid in moisture removal, hopefully!
For the drain points im going to use radiator drain valves, im trying not to use compression joints at all so with the rad drain valves I can sweat them on as well, the only compression joints used are entry to the regulators. I also used 45 degree elbows for the drops to save bending the pipe and weakening it, although I bent it in other places so pointless really
Table X pipework is rated to 58 bar (for water) 0.7mm wall thickness so 10 bar compressed air should be safe.
Once Ive sweated all the joints and compressors in the shed, I'll post some more pics up and of it working to!
Gaz
Table X pipework is rated to 58 bar (for water) 0.7mm wall thickness so 10 bar compressed air should be safe.Once Ive sweated all the joints and compressors in the shed, I'll post some more pics up and of it working to!
Gaz
and that only ever got to a maximum of 100 psi (6.8 bar).
there compression fittings and reduce the pipe when they tighten up otherwise they would just blow off if they didnt . the ones on my comp have run to 150psi no problem for years. they may be rated to only 7 bar but there covering there own a rses and actual burst test pressure will be double that
