DanielW
- Merseyside Straightjacket user
it doesn't stretch very far in one pull before it snaps, but if its worked gently it expands quite a lot
That brings back memories.
you have problems if it snappedThat brings back memories.![]()
Yeah I think its quite acceptable overallthe thing is, each letter hardly has to deform from flat at all. and it is only 2 out of 32 stickers that are affected
Me I would not bother. Its not easy fitting inside on a curved window. You have done the easiest way. The photo is quite acceptable. I would just replace the 9 and which ever other one is raised. I cant even see another bad letter on the photo lolbased on that link and what it says about the L & M series, would I be better off sticking to the inside of the screen?
I had a van with side windows which had been a roofer's crew bus and was stickered at one time. They were all removed and it was well cleaned but when it fogged up you could still see the outline of the writing and I had it 5 years.Take the rear wiper arm offI had a van with side windows which had been a roofer's crew bus and was stickered at one time. They were all removed and it was well cleaned but when it fogged up you could still see the outline of the writing and I had it 5 years.
