that was flat with no air bubbles. When it rained its like it has washed the glue away on the raised bit. Am going to re cut another 9 and a o in the morning and try them again
Thats what mirrors are for lolTell me have you had the windscreen heater on since they was stuck down?
Isn't it illegal to obstruct the rear window?
hot air gun on glassIts hard to see in photos but that vinyl looks fairly think. It might take a hot air gun to fit it! There are two main types cast and calendared.
http://www.ebay.co.uk/gds/The-difference-between-Calandered-and-Cast-Vinyl-/10000000002950459/g.html
nooooo you end up with no glassYeah I can see a propane torch is not a good idea. lol a hair dryer will suffice. If its flexible its likely to be better vinyl. If it was cheap it wont be. Buying in GB does not mean its not chinese thoughyes have had the heated screen on, no problems there, and yes it is vinyl, was advertised as sign quality, came from somewhere in Britain.
it is quite thin and very flexible, but I am not using hot air to apply it as my only source of hot air is a propane torch...cant see that going well to be honest lol.
No hotter than the screen heater onto frozen glass lol.hot air gun on glassnooooo you end up with no glass
the problem is though the glass will take the heat out of it so people will put more into itNo hotter than the screen heater onto frozen glass lol.
Obviously you have to be sensible you are not trying to fry it just make it malleable.
Oh I'm just wondering if the heater might be making it hot,hence the peeling? but the reality is that the window has to be squeaky clean for them to adhere.
If he gets the glass that hot the vinyl will be running/the problem is though the glass will take the heat out of it so people will put more into it
Halloween style lettering, written in running bloodIf he gets the glass that hot the vinyl will be running/
falling off the screen !
Then your window is not squeaky clean,got nothing to do with edges being rough.
Try cleaning the window with methylated spirits and use a micro fibre cloth.
