Hi all, I have a Bosch 4.5" (PWS 720 115) which isn't working and wondered if it can be repaired or should I get a new one.. It's about 5 years old but doesn't see an awful lot of use, although I am using it more and more..
The motor runs at full speed when I turn it on but the disc turns slowly and stops completely under load. Taking it apart there is a small bevel gear on the output shaft of the motor, which turns the larger one. The small gear is completely free to spin on the shaft and has a few mm up and down play also. Should it be fixed solid to the output of the motor? It seems to me like the motor is turning but the gear isn't, although I'm no expert.
I'm restoring a mk1 caddy which is my 1st welding project. I'm getting fairly stuck into it and have next week off so could get a lot more done, I'll need my grinder though so is it a repair or replace?
it just started to get hot quickly when using it, it had seen a lot of work and just retired its self
