mike 109444
There are a few people on here who need to try out a petrol driven grinder!Everyone bangs on about 9" grinders as if they are out to kill you, just use it properly and within your limitatons ie. strength, position and you'll be fine. Using any kind of grinder to cut 6mm is sheer lazyness.
In the past I've noticed that a lot of this type of gearing relies on a thin 'cotter pin' running through the gear and shaft to maintain drive. These are designed to snap under excess load so as to not stop the motor and cause it to burn out. Although in itself it's a good idea, finding replacement pins can be a nightmare after a few years as models are changed far too regularly for suppliers to keep on top of the need for more & more parts to keep older models working.
I refurbish a fair few grinders, and I always find all the grease has been thrown off the bevel gears, when I open them up. What the answer to that is I don't know, a sealed oil filled bevel gear would be impractical. I doubt its even worth greasing them.
well with nothing to lose stick the gear back on the end an weld it to the shaft, just protect the windings with somethingTo update this, I got some loctite glue from screwfix and glued the pinion back on. Left it a couple days to set.... lasted about 60 seconds. New grinder time...
