phasesonix
This is the second time this is happened- First I thought I had pushed too hard with a tack rag then thought water contamination- I have a compair air dryer with 2 stage filters going in and out- the one coming out doesn't have much water in the bowl so I'm guessing this is water contamination because of the air dryer not cooling the hot humid air? It seems the thicker the coat I put on the worse it gets....
I'm spraying on cellulose primer de-nibbed with 1200 grit, then I washed,rinsed,dried,panel wiped,tack clothed,panel wipe again and tack cloth again and then paint(cellulose)
(photos attached)
(photos attached)
