BrokenBiker
- Newport, South Wales
i do too but haven't bought one in a while and lost the other 2 lol. Gonna try a forge steel this time, not had one of those yet
Have you tried the drill yet ?how long is the advent tape? I need 10M.
went with the hitatchi in the end as it is lithium ion and that will take up to 5amp battery which can be had cheap every now and then if i needed one
you need one for masonry below 6mm, one for masonry above 6mm, one for screwing at high torque, one for screwing at low torque, one for countersinking, one for steel, one for wood, one with a flapper, one with a wire brush for steel, one with a wire brush for ali, one with a brass brush, one with a step drill in it, one with plug cutter in it...oh and one for spare![]()
You forgot the pillar drill !!you need one for masonry below 6mm, one for masonry above 6mm, one for screwing at high torque, one for screwing at low torque, one for countersinking, one for steel, one for wood, one with a flapper, one with a wire brush for steel, one with a wire brush for ali, one with a brass brush, one with a step drill in it, one with plug cutter in it...oh and one for spare![]()
Not got a mag drillmag drill?
