Germanlkmanx
I think my Portamig 181 is broken *UPDATE - problem solved*
Hey Guys,
Tonight I went to hook up a new gas bottle to my Portamig 181. While I was making sure the regulator was set-up to my liking I turned the power down on the wire speed to avoid wasting too much wire. Unfortunately when I turned it back up it no longer feeds!
I can still hear the motor/solenoid clicking but there is Zero movement anywhere. I took the side off and all appears ok, everything in place etc, no heat in the motor or anything else worrying...
I have always thought the wire speed was a little strange with it, I had to have the speed set around 7 out of ten to achieve I decent feed when welding regular auto metal on Course 2 Fine 1. Also it always seemed to have intital problems feeding until it got up to speed, i.e. it would be ok when running a longish stitch but sometimes not feed immediately after pressing the trigger when spot/plug welding (Eurotorch). The roller tension and wheel tension is not over tightened. Either way, I think I may have just killed it.
Any ideas anyone? Thanks in advance...
Tom Kettle.
Hey Guys,
Tom Kettle.
although results look OK.
They are "aware" of this issue of the wire speed control not working until way up the dial
Just gald Tom is up & running again without any major issues.
just for a bit of plastic, so I've never bothered stocking em. You should get perfectly acceptable flow settings from your existing regulator?
