atomant48
- Salisbury, UK
We'll I just replaced the standard earth lead and clamp on my 151 turbo and really can't believe the difference it has made. Arc is much more stable, settings aren't as "fiddly", and it doesn't seem anywhere near as fussy about where the earth is in relation to the weld.
I used a 200amp clamp (the physical difference is quite obvious) and joined the original into a dinse panel plug. Other advantage is the cable is now much longer. Would definitely recommend doing it.
or you could do a dinse plug conversion if you have a euro torch too, makes transport easier imo
