hello just found the site and had a brief look round thanks, ive done a bit of gas arc and mi welding years ago not much and only on at least 3mm plate... so i want to get a mig and play. I live in france where the voltage is i think 220 at 50hz however i want to buy the welder new from the uk. maybe it would be better to buy a french one but the uk cost will be much better. i presume if i buy brand new the spec should run here?
I need to run a new cable from my fusebox to the welder it will be connected to its own individual rcb on the fusebox should i get 32 or 40 amp? The socket will be about 25 metres from the fusebox so with voltage drop heat etc would it be best to run 4mm 6mm or 10mm cable?
the fuse box is earthed with 6 rods and 25mtrs of bare 16mm copper wire (all buried) but would it be necessary or prudent to run a seperate earth spike from the socket
Lastly this is the welder i wnated to get ive bought other sealey tools and been happy with them but i would welcome any thoughts or comments
http://www.ebay.co.uk/itm/Sealey-18...Home_Garden_PowerTools_SM&hash=item43b590222e
aah ive just checked not sure if its a no gas mig?
this looks better?
http://cgi.ebay.co.uk/ws/eBayISAPI....akeTrack=true&ssPageName=VIP:watchlink:top:en
i hope to use it for metal up to about 5mm but i want to try and weld car panels aswell and i would like a gas/no gas welder
thanks for your time hopefully ill get my new toy
this looks better?
Anyhoo; for very short runs I favour the overhead cable - assuming that it's legal. My workshop is less than a metre from the wall that the cable has to pass through, so it doesn't need much in the way of support. Even so I intend to use some decent quality (stainless?) wire rope to hold it up and plenty of slack in the cable(s) in case the garage sways a bit in the wind. It shouldn't as I've added a hell of a lot of weight to the construction for just this purpose. I estimate that my half tonne building (all steel construction) now contains over a tonne of steel braced wood roof trusses - and I've yet to add the hefty ground spikes and concrete! Fortunately it's protected from the worst of the weather on 3 sides by the house, a brand spanking new 5' fence and several trees that have easily withstood the worst that several years of weather have thrown at them.
