Bill Edwards
- Scarborough, North Yorkshire
I'm looking at a '93 Mercedes 310D van which has very extreme tyre wear on the front nearside tyre. The tyre is very good but is showing more tread on the inside than the middle and a serious loss of tread at the extreme outer.
The other tyre is slightly more worn on the outer but not by much, and doesn't have the extreme wear on the shoulder.
The kingpin was replaced in January, a little before that that side leaf spring was replaced. The wheel bearing doesn't have an excessive amount of play, nor do the steering joints. The spring doesn't appear to be broken, the axle doesn't appear to be in the wrong place (forwards/backwards). The camber doesn't appear to be wrong by eye (no gauges to hand). The vehicle appears slightly higher to that side, but not by much and is probably the leaf spring (or an uneven load, or where it is parked as the ground may not be 100% level).
Any thoughts?
Any thoughts?
