It might initially until you look at the spec,Hmmmmm, that looks better value.
Yeah with those or 4130/moly which spring back that figure may be as low as around 50degrees?Wonder what it actually bends to when it's 2.5mm wall and CDS or T45 then...
do you have any info on how to operate 1 of these benders as I have the chance to buy 1 but not sure how it all works ive used other benders before but this seems a lot different. also what would be a good price to buy 1 of these well used but with quite a few dies with it. thanksOk, you'll need a rotary type bender, a bit similar to a copper tube bender that pulls the tube around a former with a guide that runs around the outside,
The type that pushes a hydraulic ram in the centre of the former with a die either side will only do the softer seamed chs type tube, all other types of tube will collapse in the bend area,
Unfortunately tube bending and cheap dont mix,
You'll need something similar to the JD squared or Stakesys machines to do cds or t45,
I use this one on cds and other seamless tubes.
Has anyone gone down those route?Build your self a Gottrikes.com bender, Frank the owner sells the plans for about $15. Then buy the required dies from Protools
I have instructions (somewhere) for the red tube bender i put a picture up of,do you have any info on how to operate 1 of these benders as I have the chance to buy 1 but not sure how it all works ive used other benders before but this seems a lot different. also what would be a good price to buy 1 of these well used but with quite a few dies with it. thanks
I'm currently agonising over whether to treat myself to an "Affordable Bender" from the US. There's a deal on ebay for it with a full set of dies (that works out around £600 at the current exchange rate - that's including customs and shipping (or so it says).
What's got me umming and ahhing is that I'd want to bend exhaust pipe too to make it pay for itself which means a mandrel realistically. I was thinking I could add a second frame similar to the standard one sticking out at right-angles with a bar attached in the middle to hold a mandrel. But I'd also want tighter radius bends as the standard dies are 7" CLR and on exhaust pipe I'd want to go up to 2". I think it would be a good basis and lend itself to doing what I want with the additions I'm thinking of but it's all extra stuff I'd have to make or buy with no 100% guarantee it'll ever do just what I want.......
I just need to see a dip in the dollar's value to persuade me.
Iain
WAs the tube bending not god then??It was looking (all be it boring) interesting up to the tube bending![]()
I wondered how it was different thanks for confirming it lol.No. That setup is no different to the cheap pipe kinkers on ebay.
