normspanners
An electricians view on this please, Voltages are approximations BTW ie not taking rms into the equation.
I am having, shall we say a 'discussion' at the moment with an electrician regarding a true three phase welder
He says if it is 240 /415 it doesnt matter if it is wired star or delta because it is 240 or 415.
I say in this country you would never wire it up 240 because AFAIK the 240 is for the US market etc because their phases are 110 ish and therefore it actually is 110-110-110 /120 deg angle .220 across any two.
In this country it is 240-240-240 /120deg 415 across any two.
Correct me if I am wrong, I say you could damage the welder by linking it 240 3ph because it is not designed to do this.
He says it is only similar to a 240/ 415 machine where you use one or two phases
I say that a 415 'two' phase wired machine is still actually single phase because it only uses one sinusoidal wave through its transformer and that, one of phase wire actually becomes the neutral return, depending where in the cycle you are.
He says that both the phases 'give' IE two sinusoidal waves, I say that would never work because you need a neutral from somewhere.
Views on this?
Norm
Views on this?
Norm
