Hi all,
I can rant a bit so please be patient!
I've just signed up as I've been awake for 2 days trying to work out if its worth the investment to buy and learn to TIG weld. I'll be as brief as I can..
Me:
I have no experience of welding but my Dad was a welder so I remember a lot of theory, plus the internet helps. I'm a very practical person and quite good at engineering/researching - hard to describe my practical skills here but if I say you picked 100 people off the street and taught them to weld, I'd be one of the fastest to pick it up
I'm one of those people that picks things up quite quickly. But as I have never welded I don't know what the learning curve is going to be.
The situation:
I need to make a custom aluminium fuel tank, build a new subframe for a 180KG engine, re-enforce the chassis and do some minor cleanups (patching up, some mounts and little body work bits). The most critical bit of work that I'm worried about is the subframe. The chassis is effectively a ladder/monocoque chassis, and I've cut out the chassis beams immediately before and after the engine (MR layout). I need to weld new beams in place slightly further from the engine at the front and back, and onto these new beams the new subframe will hang. So all the engine will be supported by (potentially my) new structures.
The finances:
I estimate that for a cheap chinese AC DC TIG welder at £400, I'd need another £150 of various bits including upgrading the power supply to 30amps (single phase still). After that it will be £60/year for an argon bottle rental and £50 for refills. So call it £600 setup fee's, and maybe £20/month in disposables
The questions!!!
1) With the amount of work described, do you think its more economical to pay someone to do all the work or for me to invest in a TIG welder? I had a quote for the fuel tank alone and that was almost 4 figures :S
2) Do you think that with enough practice within a few months I would be competent enough to safely weld new chassis beams and an engine subframe?
Thanks in advance - I hope you can make sense of it, and understand why I'm so undecided!
Me:
I'm one of those people that picks things up quite quickly. But as I have never welded I don't know what the learning curve is going to be.The situation:
The finances:
The questions!!!
