Smackfiend
I've just sprayed my car with cellulose filler primer and I've got horrendous paint runs!
The car was keyed, panel wiped and tack clothed.
The filler primer was mixed 1:1 with thinners.
It was about 10ish degrees in the garage and started to go on okay but after a couple of minutes it started to run, even if I applied a light coat to other areas of the car.
Is this too cold to apply cellulose paint (ie the actual car is too cold)?
Or is there something else that I'm missing?
Also does anyone know if the etch primer underneath would have been removed / melted away due to the runs in the filler primer?
Thanks in advance, Ian
you can call me what you want but Peter is what I answer to.
