carl0s
- Kelsall
Is it safe to run my cheap air tools without a regulator, i.e. at ~150psi (I think that's what the compressor's cut-off is set to.. )
The specifications of most tools tend to state 90psi.
I have bought a regulator - a Sealey regulator/filter & oiler combination thing, but after seeing how rough it looks, and doing a bit of searching, I'm realising that it might just be unnecessary crap, and not very good at best. It's the same as all the other cheap eBay regular/oiler combinations. It came with two 1/2" - > 1/4" reducers, and the threads are so badly cut on those that no amount of PFTE tape will get a gas tight seal. Christ knows how bad the actual regulator-y bits are.
I'm generally only going to be using a 3/8" air ratchet, occasional drill and chisel and what not.
I realise that painting requires water traps, pressure control, etc. but I'm not worried about that for now.
Thanks,
Carl
Thanks,
Carl
if they were ment to run at that pressure the manafacturers wouldhave said so
price of a norgren water seperator regulator free
