- UK
Other issue is going to be cutting a large hole in the side of a rented industrial unit for the exhaust!
They'll let you do it at your own expense and then increase the rent because of the improved facilities. :full
I hope to make mine a positive pressure booth (clean air being blown in)
So I’ll have two fans plus ducting for the space heater and maybe a fan for the outlet
Any leaks will blow out so dust getting in shouldn’t be a problem
just have to do a brick partition wall across the front doors when you leave then.you can put anything in you want. Fine. He then said if you leave it in we wont charge you to remove it.
Hopefully the clean air should force the fumes out
I’ll have a single exhaust fan on the output side
The air going into the booth will be filtered
Looks like youve given Mrs WP an electric gun with a short in it.
No, her hair always looks like that!
Si - dunno how to size the fan i need. Can you assist?![]()
