I have a trailer axle that has a bolt around 85mm long that passed through a suspension upright, into a round tube which has a stub axle inside and then back out the tube and the other side of the suspension upright. The bolt is about 10mm.
WHile undoing it, the bolt end sheared off about 10mm into the metal work, so I tried removing the nut and that stripped the thread.
So, I ground back the stubby bit of bolt left behind and centre punched and then followed with a drill to start drilling it out.
I did this from both sides.
The bolt head side I am about 45 mm in at 8mm drill bit and the other side, I am about 20mm in, with 8mm drill bit.
I managed to snap a drill bit in the 20mm hole which is now stuck fast and despite trying to pull it out/use a centre punch to release it, its stuck and with drilling I have chipped some away but now its stuck fast and drilling is now existent.
Now the other side, I decided to keep drilling, using Heller Cobalt drill bits I started doing well but now, the 8mm drill bit appears to have ceased to drill (well very very very slowly)
I have been using some aerosol cutting fluid (Techtone C05 or similar sounding stuff)
For the drill I have being using a combo of Bosh 450w drill and cordless Makita 18v with speed control.
For now I have given up with a view to removing the axle and taking it to an engineering place to see if they have more luck as this week I have spent about 10hours drilling & swearing at it!!!
Any tips? Its gone past an easy out, oh and I have tried some heat but its a standard Butane DIY burner.
