cumbriasteve
Moderator
- Cumbria UK
Bought a PIR LED security light, it came pre wired but only 20cm of cable.
So..decided to open it up, remove the short length of cable and replace with what I require to go through the wall to the switch etc.
Have noticed the earth is not connected to anything inside the light unit, is this correct and more importantly safe?
I just imagined a metal cased light unit that sits outside in the weather should be earthed.
It will be above 'touch' height, but not when I am up a ladder adjusting the settings.
. If it above 2.25m its not that big an issue. Fitting an earth would be a good move but keep the ip rateing or drill the hole in bottom to let the water out!
