Cheers Zardoz! I've had this machine for a long time and I've discovered really that mig welding with this machine isn't really all that versatile.
For example recently I resurrected the machine because I want to weld some nuts onto a pair of brackets which hold a guard onto my rally car. Putting the guard on and off is really tricky trying to tighten both nut and bolt together.
But, I'm going to need to clean these brackets immaculately, if I grind off the surface then am I inviting rust? There is no room to put a flap wheel in there anyway. Then I've got to get a good earth. No idea where I will get that as again no room on the welding area. I think it's an M6 nut but i have no idea what material the brackets are or what type of nut to use? If the bracket is steel and the nut is zinc coated for example will the two weld to each other? I'm going to end up making a hash of it I am sure.
On the reel front, as I swapped a 0.8 for 0.8 I must have the right roller as it was fine before.
Final question - when I weld and I am staring at the torch through my mask I can still see a white spot in my vision afterwards - is that normal and not damaging ?
