gordonendersby
Hi all,
What tools should I be looking at for setting out work pieces.
Ive got an engineers square on the way for xmas as the wooden woodworking one was looking a bit fragile around hot steel.
Ive got a couple of arrow head magnets for 90 and 45 degrees.
and obviously an assortment of clamps. I should imagine you can never have enough.
What do you use as a protractor for varied angles?
Is there anything for helping out with the sort of ellipses you get when butting up against tubes at angles? Small stuff I could imagine doing by eye and trial and error. Do you use something like a profile gauge decorators use?
Which is a row of rods in a holder that can form around an irregular shape.
Are there any other tools for setting out hobby projects that I should consider?
For example Im going to make a stand for the wife's bird feeder, as a practice piece, which is going to involve some 20mm box section butted to 25mm or there abouts tube at right angles and 45 degrees. So there are ellipses to be cut into the box section to weld to the tube. I could do it by eye or make a template and do some maths to get the ellipse correct.
Or is it all just bits of cardboard and trial and error before cutting the metal?
Thanks
Gordon
Thanks
Gordon
