Looking good, you just need to keep everything a bit tighter, on the first photo it looks as if you strayed out onto the bottom plate a bit far, with a bit more practise you'll have it cracked
The fillet is looking a lot better, the lap joint is a bit peaky and you're not getting a smooth transition at the toe of the weld, try playing around with power settings, angles and travel speeds a bit
angle the rod towards the lower plate?
i seem to run them hotter,120ish for flat.we were given budget rods for a week,Geko.slag was a right effort to get off.i wouldnt mind but the good rods,Oerlikon,they were getting for a quid per kilo!
90 is very cold, 115 is normal i could do it vertical at that. Better off way too hot than too cold, you could do it at 150 no problem
Didnt realise it was a 4 mm plate want to be moving pronto, im on a full time day course atm cause I'm welding years with no codes, tests next week. 12 mm to 10mm t fillet mig, 6 mm t fillet mma and 3 mm mild streel stainless steel and alu t fillet tig.
Ya its a fair size, bit needed with all penetration issues with Mig, and that's what you have to prove, no i use 0.8 mm wire actually. I know the way. Next full time course over here is intermediate and its all plate butt welding in vertical position, with e6010 aond tig roots etc, its 3 months full time, then 4 mono the advanced pipe welding. Once you learn tig and get good, your mma will come up a gear automatically
You will visit the bench grinder many times the first week sharpening tungstens,but tig welding is all about teaching the wire feed to your bad hand and tig revolves around being good at feeding. You will get there very enjoyable like stick, not boring like Mig welding
sounds like a good course
