Nope, don't think so. Looks like this
Finally got a new gas bottle, hoorah!
Man sized too.
Spent the next 4 hours getting angry, fiddling with settings and making holes. Eventually filled more than I made, and ground them down a bit before the light went. It's not quite perfect, I'll go over it again with a light flap disc when I come to clean up the entire wing and get it smooth and flat.
I then had a first attempt at making a template for the speaker/switch panel that will replace the dash tray on the drivers side. Ran into a few problems here, my first choice plan was to go vertically straight up from the front edge of the bottom lip, and then extend out to the top and sides to secure...just look at the photos. Problem here is I can only fit a 10cm speaker there, at a push, and I'd rather not give up the 13cm Phonocar speakers I already have. Not only this but the speaker is directed at my midriff and has a 95mm 'roof' above it.
The other option is to follow the line of the dash panel. This would allow me my 13cm speakers and there'd be no 'roof' over the speaker, but it will then be angled down at my legs. Either option will be better than the old set up of them being tucked under the dash pointing straight at the floor though.
Man sized too.
