Must admit i kind of agree with BS... for some work gas is and will probably remain a far superior method than any CURRENT alternative.
No pun intended !
The company said it was looking at building a dissolved acetylene plant at Immingham in Lincolnshire.
was it ever built ?
unfortunately
I wonder if acetylene generators will make a comeback?
it IS the pressure of acetylene thats the problem
go look on your bottle to see whats in it
15bar tops
Time to start working on an adaptor for the end of the cutting torch to hold limestone and water then
I get the impression that the British authorities have gone a bit overboard with H&S.
Interesting stuff and no definitive answer.
Sounds as though it is on it's way out.
What would you need to convert to oxy propane, I use it almost exclusively for brazing.
I heard to mates discussing it and their theory is that proane is 'too dirty for brazing and welding' are they talking fromage?
u cant weld with propane the center cone isnt hot enough but u can braze with it no problem and the flames clean . flux is used to clean the joint anyhow irispective of what gas used or how its heatedInteresting stuff and no definitive answer.
You'd be better off with calcium carbide rather than limestone (calcium carbonate). You could use limestone in a CO2 generator for MIG though![]()
