who knows about landrover pto's then, l have been given a sunday 300 tdi disc which seems to run well enough, l have a need to mow a big field this year every 2 weeks or so to beat the docs into submission, l have a big tow behind hayter mower, it is usally fed with a shaft from a tractor which turns a hyd pump which turn the blades but l dont have a working tractor but l do have a free disco
so the questions begin , l assume a pto on the back of a landrover lt77 or R380 gearbox will be driven of the main shaft ?, is this affected by which gear l am in ? but the low box will have no effect on pto speed ? so l can select low box and change between 1 2 and 3 on the main box to find a suitable road speed to mow, does 5 to 10 mph sound about right to mow at ?
anyone know how fast the pto would be turning at 10 mph when l am in low box ??
the pto into the mower from a tractor turns at 540 rpm l think, it then goes through a 3 to one gearbox so l think the pump is looking for around 1500 rpm ?
l guess l could run a prop to the mower input or remove the pump on the mower and fit it to the gear box extending the hyd hoses ??
suggestions, other than fix my tractor ??
