id like to know what peoples preferred way to cut metal is,and any advantages/disadvantages different methods have.The only things i have used are my 4" angle grinder,which is good but larger work pieces have to be moved to cut all the way around,and a hacksaw time being the issue with that one even though they are accurate.Im thinking of buying a 9" grinder and maybe a chop saw after ive read up on them abit.
....vari pitch blades on bandsaws cope well with all materials without changing ,our cold saw is not as good for light steel and requires a light touch,powered hacksaw (machines) are an alternative but are slow but if cheap enough worth considering....Abrasive cut off saws or rage type blades have their uses but are noisy or dusty...make ideal site tools ,my neighbours wouldn't be impressed though...They can all be very accurate,cold saws and well set up bandsaws are more than adequate for most fabricating and machining work and would always be my first choice ,but every type of saw will have its own fans
) that's what I use for the same type of material and cuts at work.
