Tiggy_dorset
It looks just like a bought one!
- Weymouth, Dorset, UK
Thought I would post up progress of my cabinet build so far. I have taken ideas from different sources, so if you see an idea here that was originally your own, I thank you for the inspiration.
Starting with an oil drum, I needed to make a door. Simply 2 different diameter sheets of ply glued together and mounted to the drum on 3 studs welded to the inside of the drum.
The window unit is simply a wooden photo frame (with glass) bought for £6 from B&Q. I mounted it to a seperate wooden frame I fabbed myself to allow me to shape it to fit over the ribs on the drum.
I lucked in with the frame. Picked up some tubing which was originally a trampoline, from my local tip. A bit of cutting and welding to shorten the length to fit the drum, and hey presto! The legs are push fit so can be removed if I want to transport the frame elsewhere. The bars came already bent with a slight V shape, which is a nice touch for the drum to sit snuggly on without movement I thought
Hopefully I will have more pics of progress my the end of the weekend.
and am cutting a couple strips out of some sheet, ready to be folded as part of the base of the hopper.
and very jealous of the nibbler
Chasing holes and spot welding all over the place meant for a not too pleasant sight. Being displeased with the result I decided to grind it out and redo it. the beauty of the 2nd attempt was the fact that I now had a little more metal to weld to.
