a 306 will be ok just to change the bulbs to 100watt without altering anything as long as no higher wattage than that. ive had them for years in peugeot partner vans and the 106 car we hadAny way of working out what relay, fuse and wire rating i need to be looking at to run 100w bulbs?
have you calculated those figures out and if so could you let me know how you did it? Is there an equation for working out wire thickness to attain the correct resistance? More out of curiosity than anything? Ive worked out the resistance of my current wires with my 55w bulbs so that gives me the resistance i should be looking for with the 100w bulbs and new wire.
Thanks Robotstar.
On the relay there are a few different types is there a specific type i need?
SPDT
SPNO etc
What does each do?
What if i wanted my dipped beam to stay on with my main beam?
and re-connect to the first one.I started to get lost at post 41 ...lol.....so much for my mech to elec training .......golf was easy though.....well done Stu/BS
I've always enjoyed auto-electrics, although modern cars with multiple ECU's don't like having the wiring messed with, can throw up all sorts of problems.
.....with the relay's and brighter bulbs (legal) i'm well pleased ....Keeps Anto out of trouble for a while
i prefer 21 year old golfs....no ecu ,no electric windows ,no central locking ,no lambda or catalyst obviously ...aircon ...open a window or drop the roof.....with the relay's and brighter bulbs (legal) i'm well pleased ....Keeps Anto out of trouble for a while
Not as yet,what were the symptoms?..had a 89 scirroco before the golf no problems either.....things do fail ,i'm not blind to their problems,but can normally fix myself without using garages...Have you had any problems with the instrument binnacle?, I had a load of trouble sorting an '87 Polo, traced problems to PCB behind clocks.
Have you got a wiring digram for the car? it will show you what colour wires go where and what they do. Look for one from the light switch to the dip/main switch, then find the one from the dip/main switch to dip beam circuit, this is the one to cutand re-connect to the first one.
If it was british, the first wire would be blue and the second blue/red.
