Before I had a lift, I put up my old FL1 on four axle stands and crawled under while it was running in gear. You’ve got to be a bit careful, of course, but a long screwdriver works well as a stethoscope. In this case, it was the front prop support bearing, and I could also feel the vibrations from it, just like you can feel the vibrations from a bad wheel bearing if you grab hold of the suspension spring while spinning the wheel.My trusty Freelander 2 has decided it wants to have some mechanical attention, thoughts please from the experts.
It has developed a growling noise from the front which sounds for all the world like a wheel bearing failing. I know it can be notoriously difficult to diagnose which bearing is causing the problem. No play detectable with wheels jacked up and no obvious noise at the hubs while turning either wheel. It just passed mot 2 weeks ago with no issues reported. There is a very slight noise from the area of the front ptu as I turn the drivers side wheel / drive shaft but im not sure if its just a normal mechanical components rotating noise or it it's indication of the problem being there.
My next idea is to remove the drive shafts from the hubs, to be able to spin the hubs on their own without any other transferred noise from the driveshafts / ptu / gearbox which might prove if either one is causing the issue.
Failing that I suppose im looking at replacing the PTU (and splined coupler).
Any other tips, tricks or advice in diagnosing this issue?
I had a grumbling PTU, first thought it was tyre noise, then wheel bearing, nothing found. Then I checked the input shaft of the PTU and there was loads of free play. Very obvious. I've got a video somewhere...Further info on the FL2, check the intermediate bearing on the OSF driveshaft - known to get 'notchy', they can be replaced separately.
Coincidentally, one of the staff FL2's has a grumbly PTU that's being exchanged tomorrow, the pinion bearing is the culprit and can be checked with chassis ears or checking for lift/oil leak on the pinion.
If you take the PTU out, replace the splined coupler and grease - NOT with copperslip!, use a Moly-based grease, i.e. CV joint grease.
Coupling sleeve & it's box
View attachment 539712View attachment 539713
Replacement PTU - don't forget to fill with oil!
I'm veering towards this being the problem, noise has got significantly worse over last few days, think Spitfire on takeoff!Further info on the FL2, check the intermediate bearing on the OSF driveshaft - known to get 'notchy', they can be replaced separately.
Ill stick it up on axle stands and run it with all 4 wheels off the ground and have a look and listen.
Bet he never tried that with an Alfasud, Alfa 33, Citroen BX...On a fwd car there is a simple method to check a wheel bearing. Park with 1 front wheel on the grass verge. Put on the handbrake, select 1st and let out the clutch.
The wheel on the grass will spin unless you have off road tyres or a lsd fitted. Rock the steering from side to side to put some side loading on the bearing.
Repeat for the other wheel. An old school mechanic showed me this tip to narrow down which wheel bearing was noisy. I have used it a few times and it usually works.
Ever heard of ABS? - do that on a car with it and it'll give you a result you didn't expect....On a fwd car there is a simple method to check a wheel bearing. Park with 1 front wheel on the grass verge. Put on the handbrake, select 1st and let out the clutch.
For wheel bearings, swerving left and right on a quiet stretch of road can help decide which bearing is noisy. The noise will increase when you’re swerving away from the bad side.Its a 4x4 on AT tyres, thats not gonna work.![]()
Frankly it's not a good idea, if nothing else, I'd be surprised if you could hear anything above the sound of a tyre scuffing the ground, and let's hope it doesn't flick a stone up whilst you have your head out of the window or tear a neat circumferential groove in it from something sharp just below the surface...
Any ABS in those circumstances would reduce the power to the spinning wheel, traction control or not.
Well all the basic ABS systems on the basic 2WD cars I've ever had up on a two-poster with someone inside 'driving' it - and the ABS braking the wheels / cutting the power must've had an undiagnosed fault then.Basic abs will only stop the wheels locking under heavy braking. My van is 2014 and that's all it does.
I know more modern systems apply the brakes to a spinning wheel.
It's French, of course it's unique!Well all the basic ABS systems on the basic 2WD cars I've ever had up on a two-poster with someone inside 'driving' it - and the ABS braking the wheels / cutting the power must've had an undiagnosed fault then.
Or your van is unique.
