Onoff
- Sevenoaks, UK
Somewhere else.
Why? I figure if on the patch they'll be easy to add stuff to. Then when ready easy to tip out.
Somewhere else.
Why?
Moved the apple tree grafts outside, My first attempt at grafting
and put one of those deer fences round it
That was my situation, mine were from an old landfill site that has quite a number of apple trees self sown on it, Im pretty sure most are not recognised varieties but the best ones are superb, I pruned a few of them & they did well but are getting buried under brambles & hawthorn scrub.How do you do that then? Got some great tasting trees here but very old.
Grafting is where you take a known rootstock that will produce a full grown tree of a certain size & graft (or splice) a Scion oto it which is a piece of last years growth from the tree you want to replicate.
Rootstocks range from Dwarfing, Semi Dwarfing, Half Standard or Standard. I chose an M26 semi dwarfing rootstock which should produce a tree up to 12ft tall, Suppliers send out rootstock trees in midwinter for you to do the grafting in the early spring just before the sap starts rising. The bits fuse together & heal up becoming one tree.
Virtually all fruit trees are grown this way as you know what you are going to get.
It is possible to graft multiple variety scions onto a common rootstock so you might have 4 or 5 or more different apples on one tree.
There are loads of vids on you tube showing how to do it.
I will be planting the best one along the fence & espallier train it, This is where you train branches each side along a wire in horizontal rows so as to make a compact low tree.
It is good to obtain rootstocks from a reputable nursery, We once got a Greengage tree that was supposedly on a Dwarf rootstock..... It wasnt, In fact it was a standard & got very tall very fast, in the end it was so rampant that we had to remove it.
You can definitely graft different varieties of the same fruit as one tree (eg, bramley and cox's apples) but I don't think it works with different fruits.@Keith 66
Is it possible to graft a pear and an apple to some root stock at the same time?
Swedes.....
Not this SORT:
But the vegetable. I do not understand these instructions on the packet. "Sow in drills 0.5cm deep", no problem.
However, "...40cm apart and thin to 1 plant every 12cm after 4 weeks".
A "drill" in this case would be a "row", so "sow thinly in 0.5cm deep trenches which are 40cm apart. thin plants to 1 plant every 12 cm along the row, after 4 weeks"
