- Birmingham
Left in an empty flat.
Site manager is completing the paper work so it can be re homed
One for @doubleboost
If you were closer - I've got a whole load of wider shelves for that stuff.As I cycled home from the shed I noticed some metal shelving sitting at the side of the road with "Free" written on it. I don't need any shelving, I've already got as much as I've got space for. Obviously I decided to go back for it, at first I gathered some tools with the intention of taking it to pieces on the side of the road so it would fit in the car. Then I decided half the bolts wouldn't come undone and I'd be left with a problem, so as it's really close to home I decided to walk back to get it. This time, though, I remembered I've got a trolley at home, so I walked around with that.
It's not Dexion, it's a bit lighter weight than that, it is stamped NC Brown on the uprights. All I need now is somewhere to build them.
Big investment,have you a market? Good luck.After I semi-retired 3 years ago, a business opportunity has presented itself over the last year or so, so I've invested and set up another business...
View attachment 539047View attachment 539048
Be aware (you may have been) that these "new" type 4Ahr ones are ONLY 20v not the 20/40 as per older type.Kind of "middle of ALDI"
popped in for food bits and spotted 20V ferrex batteries 4Ah for £14.99 ( 4ah usually £24.99) looked like flashy version of the ones i use in 20V brushless ferrex grinder so got one.
Seems to slide in ok and grinder working (i did check terminal markings and + /- looked same.
Will try charger later..
