Yes, but now that bit of paint is missing he's going to have to redecorate the entire house, and while he's at it, he might as well build an extension, add some dormer windows, solar and hot water panels and anything else we can think of. So there's plenty of mileage left in the thread yet.What!!! You fixed it yourself with only 2 pages of thread comments that have barely even started to drift yet. You redeemed yourself by the nice use of a lathe as an essential tool though.![]()
And we hadn't got to the 'dismantle the house brick by brick around the door so you can access the lock' advice yet...What!!! You fixed it yourself with only 2 pages of thread comments that have barely even started to drift yet. You redeemed yourself by the nice use of a lathe as an essential tool though.![]()
...before pushing from the other side just in case it toppled in.
The bolt usually has a couple of loose spinning hardened pins in it so you'd be lucky to get through it with anything other than a grindermulti tool with metal cutting blade?
The hinge pins would be on the same side as he's stood unless it's a saloon door and swings both waysMove to the other side of the door - can you knock the pins out of the hinges? Then "open" the door at the hinge side, once the door is off you remove the lock and replace as normal.
Did that many years ago with a solid wood back door that had swelled and lock had seized.
Pay attention lad.. he got in ages ago and his Mrs is sweeping up the debris..Anyway, it's been hours since you asked. Is it open yet?
D'oh. that'll teach me to start a reply and get distracted with work. When I refreshed the thread before I posted my reply, it only showed me about 10 replies. Glad to hear it's sorted anywayPay attention lad.. he got in ages ago and his Mrs is sweeping up the debris..![]()
Bearing in mind where we are, much better to have welded something to the hinge pins to allow them to be hammered out . . .I particularly liked the employment of the lathe.
Demonstrating my point of the other day perfectly....![]()
Why have you a lock like that on an interior door?
