Bobupndown
What could possibly go wrong?
- Northern Ireland
Its not but mine is equally tidy.Plus, if that’s it in your photo, it’s a fine-looking car
Try some DrTranny, good stuff.
Short term, it'll mask issues, as it's a friction modifier, it just makes the transmission more bearable until nearly all the friction material is shed from the clutch plates....Try some DrTranny, good stuff.
There's no way I'd be asking a 2007 to suddenly cope with more BHP...My mate with the 2007 RRS has just bought a ‘tuning box’ for it, and swears blind it will improve mpg and power (I’m fitting it for him).
Inside, some passives, DIP switches and two DIP chips, 8 and 16 leg. Numbers ground off. Maybe an op amp and something else?
It splices in to the fuel rail sensor, so I assume it raises rail pressure by attenuating the sensor signal. Tiger tuning, about £70. Snake oil (mpg claim)?
I didn’t know that. My guess was, because the ECU has a false rail pressure reading, it’s injecting more fuel than it thinks, so this artificially increases the displayed mpg.that causes the fuel trims to reduce the amount injected under normal driving
It got me another 6/7 years out of my well worn torque convertor on the 06 disco, in the end I had the t/c rebuilt, and it was the best it had ever driven and still does, but knowing what I now know I would have had the t/c rebuilt sooner or shifted the car on!Short term, it'll mask issues, as it's a friction modifier, it just makes the transmission more bearable until nearly all the friction material is shed from the clutch plates....
Useful if you're selling the car, un-useful if you plan on keeping it as it could cost you a set of fluid solenoids as well as the clutch plates if you have your own unit refurbed.
Same here, its not just the LR fixes its how @Ubique describes his diagnostic processes that makes this a very interesting threadReally enjoying this thread, as a Landrover fan it's interesting to read about the fixes to the various issues they throw up. Don't fancy some of the eye watering bills though, can only imagine what a LR main dealer would charge.
This!... Of course, once someone has more BHP, they tend to want to use it, negating the mpg increase possible....
I read your earlier response to a similar post, but surely the Ecu reduces the length of duration of injector pulse so records less fuel used, but the engine still needs the same mount of power/torque to move the car, so actual Mpg is the same at cruise.thereby giving a better mpg.
Because the fuel is pushed in at higher pressure, it is atomised more efficiently (this is how it was done moving the Lion engines from EU3 to EU4, although with changed injectors and 'proper' calibrations) so there is less unburnt fuel (unless you boot it, which is why mapped vehicles always black smoke when pushed) and the peak torque is increased, some maps also move the peak downwards a couple of hundred rpm, which also helps with fuel efficiency.I read your earlier response to a similar post, but surely the Ecu reduces the length of duration of injector pulse so records less fuel used, but the engine still needs the same mount of power/torque to move the car, so actual Mpg is the same at cruise.
Every time one calls for more torque more fuel is injected as the Ecu increases the injector pulse time.
The manufacturers of such maps/boxes simply rely on drivers only using the trip computer figures, never actually performing brim to brim calcs.
Stealing that one…Chinese ditchfinder tyres
…and that one. Thank you‘ugly kid' glass
..and if Volvo can do a 'Polestar' software upgrade adding 20bhp and 'improving economy' - why don't they do it from new instead of charging £700+....Stealing that one…
Just to bottom out the diesel tuning box thing, the classic question: if higher rail pressures give better performance by improving combustion efficiency, why don’t they make them like that from the factory? There must be some sort of compromise.
Emissions?Stealing that one…
VWG were early adopters of that business model.....and if Volvo can do a 'Polestar' software upgrade adding 20bhp and 'improving economy' - why don't they do it from new instead of charging £700+....
Emission controls - and mechanical stress.Emissions?![]()
I deleted the centre silencer, cat and EGR on my Td5 Defender 16 years ago - the MoT man in Devon spotted it and asked where I got the kitdeletion of emission controls makes their vehicle no longer type-approved and therefore in breach of insurance rules
Still going strong to this day.
