MattF
- South Yorkshire
If they keep doing gas they'll be total mongs before long, another drain on the working tax payer.
Nitrous? I occasionally find the canisters, on some sites.
It does depending on the zinc content in the alloy unfortunately. If it's not affecting the zinc then it's not removing the build up, there isn't a way round it due to the compaition required to do the work I'm told.I'm using that at the recommended mix and it is turning the carbs dark grey.
I usually set it for 10 mins @70 deg.
What mix are you using?
What settings do you use?
For anything that's on show I vapour blast them afterwards to get rid of the surface tarnish.
An ultrasonic alone won't leave the outface shiny it just removes the fuel deposits. Vapour blasting, chemical polishing or the vibrating ceramic beads afterwards are what brings the surface up.I regularly see people saying that their carbs come out clean and shiny.
That's why I was thinking I'm mixing it too strong.
The stuff I'm doing is garden equipment like saws and lawnmowers so I'm not worried about cosmetics as long as its clean.
The first customer job I did on a non working Stihl chainsaw paid for the cleaner so it was a good purchase.
Is the dulling of metal not simply that Ultrcarb is a caustic (alkali) agent. The SDS shows it to be two caustic agents and a surfactant.After trying a few I use Ultrocarb now as it gives the best results on carbs and small parts without being so harsh that it or discolours affects the metals/alloys.
Demilneralised water supposedly helps as it improves the cavitation, but the main benefit I've noticed is that the solution lasts a couple of washes longer using that when compared to tap water. The makers reckon Ultrocarb is fine with tap water, but I take the belt and braces approach on that.
Link to UltroCarb.
It's partly that, but it has to be an alkaline cleaning agent to remove the fuel residue. The other issue is that the zinc content in the alloy tarnishes, and the zinc content varies between manufacturers.Is the dulling of metal not simply that Ultrcarb is a caustic (alkali) agent. The SDS shows it to be two caustic agents and a surfactant.
Alkali's dull metal, especially aluminium, acids brighten metal.
Are her kids miners?Barry Scott told it's true...
I think thatNothing a good splodge of bathroom sealant won't fix.![]()
I know the Brit bike market is down, but that's crazy cheap.Speaking of Triumph Twenty One, this was cheap. Good job I didn’t go.
Bonhams Cars : The David Plant Collection, 1959 Triumph 350cc Twenty-One Frame no. H7477 Engine no. 3TA H7477
Triumph re-entered the '350' class in 1957 with the introduction of the 'Twenty-One'. Its arrival ushering in Triumph's unitary construction era, the model took its name from the engine's approximate cubic capacity in inches. Readily distinguishable by its Shell Blue metallic finish and...cars.bonhams.com
You should see if there's a "Spotless Water" location nearby, as it's a much cheaper way of getting demineralised (RODI) waterFluid change time in the ultrasonic cleaner. Maximum of five cleans, £50:00 in powder and demineralised water per refill.
or rain water caught in a plastic tub from plastic gutters, just not if the roof is tin sheets. not fully deironized < spell but almost there if just very slightly acidic.Or water from a dehumidifier.
