works with synthetic paints , not so much 2k
He always used Permobel iirc
Ebay has 1L cans of panel wipe if you want to order one for next time if it won't arrive in time for this job. I ordered this one last week and it seems decent
One of the things about bodywork I learned was to get all supllies in early and plenty of them to not stop progress
Somewhere I have a box with starchem tack cloths and some halfords paint preperation wipes which are cloth pre soaked in panel wipe. Cant find them..
But as both parts are back to primer, I can wipe with thinners before basecoat, and then straight on with clear.
I would wait until you have panel wipe. Don't use thinners or anthing else. Panel wipe.
is that so?Normal. Leave it a week then flat and polish.
I've found the same. It's a handy degreaser.Panel wipe has many other uses. It is a great degreaser and is safe with rubber and plastics. I have used it instead of brake cleaner.
If I'm going to do some painting I usually have to buy a new 5l can of it because I've used the old can up for stuff other than painting.
metalflake.com
I have followed up with 2000 , 3000 just to make easier on buff polishing situation and because I had that grade paper in stock.Still normal. If it flats out without penetrating the lacquer, it will polish. Flat it with 1500 wet.
I'm going to key and another coat of clear today or tomorrow.
Where I have the run thats messed up the basecoat, its only a small area, I am thinking I can key and spray just that area with basecoat to get it looking the same, before the clear
Its small enough that I am happy with it, but when I key the clear on the run thats going to mess it up anyway?
