Tested ok. Very oily inside plus lots of swarf. Someone was overly generous with the lube!Loos a bit frazzled on the bottom.
Why did Hoover make a 1/4 hp motor to run on 415v 3 phase ?
I'll have another look tomorrow. I've dug out star points before but it's been a while and I don't remember which end I've found them. Thanks.My donkey saw had a hoover motor which I had to dig the starpoint out.
Let me see if I can find the post or the photo.
*Edit*
Here is the post:
Post in thread 'Rewiring a 3 phase motor to Delta'
Ok. After staring at the motor for a while, I THINK I have found the Star point.
It is at the 'top' of the motor. Opposite side to where the wires are which goes to the connection plate.
Can somebody please confirm there is only one place in a motor where three wires meet?
What do you think of the photo?
Not sure if it will be of much help though.
You could try to dig the starpoint out so you can run it on DELTA lower voltage, or you can just buy a VFD that takes 220V single-phase and converts it to 380V three-phase for the quickest, easiest solution.is this for the purpose of re-wiring to delta so you can run lower voltage?
I would love to do this with my lathe so it would work better of the VFD, currently using the trick with a lower frequency, it works ok, but if i want to get anywhere fast i have to fire up the 3 phase genny and give it 415v!
Almost. Yes, I was planning to rewire to delta and then add a capacitor so the motor could be run directly from a single phase supply. This is a low power motor that won't see much use so I didn't want to purchase a vfd.is this for the purpose of re-wiring to delta so you can run lower voltage?
Yes, I have a couple of 220v in 380v out inverters. Definitely useful but not my preferred solution in this application.You could try to dig the starpoint out so you can run it on DELTA lower voltage, or you can just buy a VFD that takes 220V single-phase and converts it to 380V three-phase for the quickest, easiest solution.
Some really cheap options at Aliexpress.
Example: https://www.mig-welding.co.uk/forum/threads/cheap-5-5kw-vfd-220v-to-380v.148608/
Even the cheap ones are quite good.oh man, i thought the higher voltage vfd's were way more expensive than that, thats not too deadly!
