Matchless
I started with nothing, still have most of it left
- Essex UK
I may have found the reason my Jaguar Mk2 overdrive unit does not work! it does not build any oil pressure, I found a rod is missing, item 30 on the diagram, if someone has an A type COMPACT o/d unit could they measure the rod fitted just above the pump plug.......................the four bolt side cover and rear mounted solenoid are more or less unique to an A type compact unit as opposed to an A type unit.
