Nomad
- North Devon (for how long?)
This got parked up as a spare time job, it recently got promoted to legal and roadworthy.
A shame it's not reliable
Yesterday the starter motor died (traced to a blown 30 amp main fuse !) now fixed..
A brand new battery was fitted (the old battery was good but I needed another battery for a low priority project, it made sense to put the new battery on this)
It spins over happily but last week was only firing every 5 attempts, This week it's refusing to fire at all.
Battery voltage is over 12 volts, glowplugs are getting 11.5v for several seconds.
The engine fires straight up with a small shot of easy start and sounds strong once it's running.
Scanning error codes flagged a new fault :
P0335 / P0335(F4) crankshaft position sensor (wiring around the motor is a mess - I'll check wires and plugs before I order a new sensor)
Any idea where the crankshaft sensor is?
The older errors remain:
P1105 Dual Alternator fault - vacuum sensor circuit.
I think I've found the problem, photos to follow.
P0530 Aircon low pressure
I'm leaving this for last
