cut the boobs off, attach a couple of funnels and go the madonna routeI would welcome any and all suggestions as to how to get a good earth without disturbing the layout, Once I have that lot tacked together the rest will be easy.
or put in a couple of tubes where the N's should be and go for machine gun jubblies
I've got a police issue stab / bullet proof vest (missing the plates unfortunately) if you wanted it.In the range with a bullet proof vest on, on second thoughts, best not somebody will get tempted!
tinfoil underneath or a bit of plate on the earth return and press it over 3 or 4 nuts with your hand and tack themI would welcome any and all suggestions as to how to get a good earth without disturbing the layout, Once I have that lot tacked together the rest will be easy.
tinfoil underneath
Travelling to Scotland this weekend if you want me to chuck in it. Heading back sometime between a week and two weeks later.might just take you up on that Ed, I am testing some new type of ammunition this weekend so I will get back to you on that.
Perhaps screw a bolt in a nut and on the bench either side on all six faces add another nut and MIG tack weld the touching faces .. that should give you a large enough starting point .. hot melt glue the other nuts in place so they touch and when cool tack them up . Maybe use a range of different nuts to cover the curves .I would welcome any and all suggestions as to how to get a good earth without disturbing the layout, Once I have that lot tacked together the rest will be easy.
Probably up to North Wales then onto the M6 and up. Not sure when I'm coming back.Yes please mate, where do you want to meet up? You going up the M6?
Either setting off Saturday late afternoon and stopping off with a friend in Ruthin overnight or setting off silly O clock on Sunday.
Just not too early. The gin given to me for my birthday by some friends is very very nice.Yes, we can make that work. Anywhere on the M6 works. I will call you in the morning.
I would start laying them out at the lowest place so you build up and gravity will hold them in place as you progress.I would welcome any and all suggestions as to how to get a good earth without disturbing the layout, Once I have that lot tacked together the rest will be easy.
Are you now working internally so to speak! Won't you be able just to lay all the nuts out and drill a hole through Stephany's clone to run a bolt through to act as your earth point in the middle then tack from that outwards.
Drill hole through bolt and nut to the other side going into a nut on the "finished" side, tighten the outer nut up to hold it steady and attach earth cable to the bolt.
Dont know if you read my post a while back...screw a bolt a couple of threads into the one your tacking and use the bolt as the earth and a steady at the same time.I would welcome any and all suggestions as to how to get a good earth without disturbing the layout, Once I have that lot tacked together the rest will be easy.
Scammell wheel nuts pride of place?Maybe use a range of different nuts to cover the curves .
