While you've the roof apart how about increasing the insulation?Reality check. Short of winning the lottery any time soon I'm not going to do this hip to gable conversion anytime soon.
Strip the hip and re-felt / batten at least. Minimal effort / cost. Some new battens.
Yes, and just this last few days it has started to make some hot water.@Trevorleach are you still running your solar thermal install?
I just drilled my tiles for the pipes to go through, think I siliconed them up, might have been a PV type sealant.I have the ST tubes. I don't have the cash for PV. Things are really tight.
Strip the hip and re-felt / batten at least. Minimal effort / cost. Some new battens. If I don't sort the roof, then fit tubes and the roof leaks etc I'll curse.
Fit the stainless rail brackets I've already got.
Galvanised unistrut as rails. I've likely already got it.
Mount the 3 ST panels, plumb together. I'd have to keep them covered of course whilst I faff with the plumbing inside the roof.
I'll need a couple of those special tiles that let pipes through the roof.
The ST panels need repairs anyway but someone on another forum gave me spare tubes.
Need a tank then. I currently have just a standard copper, single coil cylinder in the loft heated by the oil boiler. Running the scenario through ChatGPT it reckons as I've got most of the bits then go for it. I've an acquired, similar copper cylinder as the existing one. Plan is to heat that via the ST loop to then pre heat the other tank. Aim is to have a radiator on the north, always cold side of the house as a heat dump
Even if it is just the cheapest rockwool or similar?
At the moment, while your house is not wind and water tight, the insulation is not going to achieve much.I'm not sure if it's worth it?
Your membrane is a one way membrane it will allow water vapour out but not water vapour or misting / blown water in . When we had our place reroofed in 2003 I was surprised at the difference it's made . No longer damp in winter & no damp /mouldy smells .
Cor I have just searched it .. that will be like wrapping the building in cling film unless you put in several louvered high up roof vents to remove any dampness that rises into the void surely ?The stuff in the picture above is the vapour impermeable, non breathable one.
That sounds too familiar...where you're standing on the lounge ceiling joists
if the structure of the flat roof isnt too far gone, you can stick rubber straight over the top of the old felt apparently, quick and easy way of doing it!Tbh the roof space here is so draughty I could use cling film without detriment. I can see daylight in multiple places etc. The roof was DIY'd (not by me) in 1987. Thank god they used marine ply instead of OSB on the flat roofs back then. The whole building needs a roof down revamp. This exercise is just to save on oil by using mainly what I have here and now without spending out too much.
they also used chipboard on flatroofs as ive put my foot through enough dormer roofs that was leaking so was needing to be replaced anywayTbh the roof space here is so draughty I could use cling film without detriment. I can see daylight in multiple places etc. The roof was DIY'd (not by me) in 1987. Thank god they used marine ply instead of OSB on the flat roofs back then. The whole building needs a roof down revamp. This exercise is just to save on oil by using mainly what I have here and now without spending out too much.
