Rust Warrior
New Member
- United Kingdom Herefordshire
I have 2 tips: they came with the welder...A couple of tips.
Plenty of ventilation as the gas is unpleasant and plenty of light to penetrate said gas.
I would also suggest practicing on some clean straight metal on a bench first.@Rust Warrior what area / work-piece lighting do you have? Improving that will have much more of an impact on visibility than continuing to fiddle with the helmet settings.
I was working outside in direct sunlight.@Rust Warrior what area / work-piece lighting do you have? Improving that will have much more of an impact on visibility than continuing to fiddle with the helmet settings.
The advice I've seen everywhere else is to practice on some scrap. My later welds today are progress. Straighter lines and better penetration.You are trying to run before you can walk.
Throw that rusty rubbish in a skip, get some clean steel and practice running straight lines on it.
Once you can do that, move on to making joints.
Two very experienced welders (@Erie Fred and @Wozzaaah ) have told you what you need to do in order to improve. With respect, there's no point asking the question if you're not going to listen to them.The advice I've seen everywhere else is to practice on some scrap. My later welds today are progress. Straighter lines and better penetration.
"Everywhere Else"......The advice I've seen everywhere else is to practice on some scrap. My later welds today are progress. Straighter lines and better penetration.
Clean scrap, not rusty old moth-eaten scrap.The advice I've seen everywhere else is to practice on some scrap. My later welds today are progress. Straighter lines and better penetration.
I wandered into Metal Supermarket in Glasgow, asked about offcuts, they were very helpful and they had them all all sorted by thickness. Rummaged around, bought far too much, and left happy with my purchase.Scrap for practice is offcuts from good clean stock, not bits of rusty rubbish that need throwing away.
Perfectly clean metal where I've ground the paint away and cleaned mating surfaces. Considering I'll be cutting away some rot and welding to some "old moth-eaten scrap" (aka my work van), I figured its damn good practice.Clean scrap, not rusty old moth-eaten scrap.![]()
Shade 10 out of 13.If you're in direct sunlight (without reflection) then it seems to me that your helmet is not adjusted correctly (shade).
You need to be able to see and know what you are looking at.
I uce fluxcore and the amount of gas coming off is ridiculous so do mind the inhaled crap.
Also, do wire brush after it'll be easier to see what's happening.
You can use old metal (you'll probably glean more fom that than shiny new) but do make a mental note of your prep and the outcome of the weld.
With regards to amps, that's a big leap from 45 to 100 and as you note, pigeon droppings to blow through would tell you somewhere in between.
I think you'll get there.
O.k........I think we have done all we can here.....time to move on....I have 2 tips: they came with the welder...
A useful tip: Get some good fluxcore wire if you want to stay on fluxcore.Thanks. I noticed the last few practice welds were a little better.
When I bought my Oxford & stated my intent to use some Flux Core - they offered me an extra knurled Roller for use with the softer FC wire for extra traction.Does flux cored require special rollers?...I only use solid and that uses smooth rollers.
