selectedgrub
- New Zealand
filled in the holes finished that housing with lotion.
I usually sell them or trade them for other fun things.........How many women you got going on?
anyway no drama and it parted off OK.
Are they not available no more?Two sets of little 8.5 degree spacers for the top inner door hinges on an external hinged Mini.
Lots of faffing on the bandsaw cutting the angles but after a brief deburr and run through the blaster they look rather good.
What do you do sit there and remember the good times in the olden days?I needed a 70mm/ish disk in a decent thickness of steel. My hole saw is blunt, completely useless. So in the lathe it went to part it off and use the backside of the holesaw as the disk. What could possibly go wronganyway no drama and it parted off OK.
some welding, not the best but more than strong enough for the purpose.
Mounted
But what’s it for…
Warming up
Up to temp.
Can’t beat a low pressure sodium glow.
The Mrs turns it on when it’s time for me to come back in from playing in the workshopWhat do you do sit there and remember the good times in the olden days?![]()
That’s scary!
You should’ve sold the modern art and bought a new wood chipper with the proceedsMade some modern art
Before actually finishing the bending around the disc to weld it up as the cover/chip exit for the chipper build.
View attachment 533101View attachment 533102
