Which mig:- output amps.....Will this power a transformer type mig .. What would be max amps. Or even a 2kw compressor
Tia
...Compressor...???These details matterI would expect the compressor to work but the generator may cough a bit when the compressor starts
it also depends on the quality of the generator, some of the cheaper ones are a bit optimistic on their output figures
Theoretically if your welder is working off a 13amp plug then it could work but transformer migs tend to have a high inrush current which will make the generator stumble as would welding thicker stuff
You could potentially get a better answer if you give details such as make and model of the various devices
Mig or Compressor highly unlikely.Will this power a transformer type mig .. What would be max amps. Or even a 2kw compressor
Tia
Once you hear that CRONK, you never forget it.A 2.4kw with a 6.5hpi-sh engine will make a noise like a pig swallowing half a cabbage trying to start the compressor,
Watching with interest toThese details matter
Thanks all for ur input... I grabbed a loncin 6500ddc so I am hoping the higher out out will cope.. 5kw continously 5.5kw peak
