selectedgrub
- New Zealand
Some chilli oil
. Nowhere to buy any 0.8mm flux core stainless wire either. Thus I decided to try some old 316 rods I had. I put one radial slit in the disc bent it into a cone with a "lap"Some bits of the circumference cut perfectly, others didn't, I think the spring clip on the plasma torch "shifts":
If your cutting tip has a x shaped groove in it it is a drag tip
If by the spring tip you mean the silly stand off - you don't need it.
If your cutting tip has a x shaped groove in it it is a drag tip, designed to be dragged on the surface of the metal with no stand off.
Use a fine flat file to flatten the face then use th files cutting edge to remake the cross + slots . Loosen the tip and remake the hole cleanly .
Perhaps also get some spares for it , they are not too expensive from the likes of ALI or Temu occasionally they are available in LIDL at twice the price for half the quantity.
put this into Ali express £10 will get a good pack
parkside plasma cutter replacement
That's useful, I didn't realise that! Then again, I've never used the stand offIf by the spring tip you mean the silly stand off - you don't need it.
How rude.Ah so![]()
When it gets like that on my hypertherm torch, i dig it out with a scriber and carry on.Looks like I've knackered the X bit. Replaceable?
